Hi! I’ve slowly creating my own Zbrush Custom UI and recently decided to change the hotkeys of my most used brushes to numbers. However, I’d like to put those numbers in the brush icons so I don’t forget which one is which, and found an #askzbrush video about it.
However the video never mentions where the default brush icons are located so one could add the numbers as was asked, only how to create a new one. I tried looking up icons in the Zbrush files but only gound the sample image and outdated icons without black backgrounds.
Is it possible to find the default Zbrush icons so that I may add numbers to them? If so, where are they located? I searched through nearly all .psd files in the zbrush files but I couldn’t find the actual icons.
