Decimation Master is freezing on certain subtools with no apparent reason, not while precalculating but while executing the decimation. Others very similar in the same model work just fine. What factors are there that I can check and fix to make it work on all subtools ?
I tried the usual procedures, empty chache, check mesh intgegrity, weld points, restart ZBrush etc.
When it does freeze, the windows task manager shows no activity for ZBrush at all.
