Dam Standard Settings and DL (Resolved)
I downloaded a 2010 Dam Standard brush from a Google search a while back, but the behavior of the brush seems odd. Instead of pinching and cutting in on holding alt, the brush has a wierd sort of planar smoothing effect that’s not what I need at all.
What are the propper settings for this brush, or can anyone point me to a better version DL?
Using ZBrush 4 if that makes a difference.
Thanks in advance!
In Brush > Modifiers, make sure Smooth is at 0.
Use the one in Lightbox > Brush folder. It should be alright.
Z! You’re the greatest.
Wasnt aware that it was in there - works perfectly, thanks!
No problem! Your welcome. If your going to do a custom UI with that brush button, make sure you put a copy of it in ZStartup > Brush Presets folder, or it won’t stick on your UI.
