Customize Edit Feature Issue
After enabling customize under Configure in the Preference’s palette, I docked the UNDO and REDO buttons from the EDIT palette just above the canvas window. Unfortunately neither buttons ever light up and hence become useless. I’m wondering if there could be a bug or is it something I’ve failed to correct. It becomes an annoyance when I always have to revert to the history palette as opposed to the quicker, more accessible UNDO and REDO buttons. Thanks in advance for your help.
Kevin
Undo- Ctrl & Z
Redo- Shift plus Ctrl & Z
I think you just moved the wrong buttons. There is Undo/Redo buttons for 2.5D and seperate Undo/Redo buttons for 3D. You probably want the ones for 3D which are in “Edit > Tool” submenu.
Doug, I did what you suggested but it didn’t seem to affect either edit tools.
Zber2, I was definitely using the 3D version UNDO/REDO from the “Edit > Tool” submenu.
My solution was to drag out and place new UNDO/REDO tools and then delete the remaining, “dead” versions.
Thank you for both of your suggestions!
