Problem: Creating own custom UI with Subtool menu which made ZBrush buggy and not stable
If you want to recreate this bug:
Create new custom UI palette and add on it Subtool menu with layers [drag and drop to your new pallet].
After few minutes working in ZBrush:
- it can crush ZBrush
- mess with new Subtool menu and replaced few buttons
- all default hot key will stop work.
How to fix?
I just use Restore Custom UI all the time when it happens BUT it happens very often.
Result: You can’t create your own pallet with tools and separate Subtool menu and speed up your work.
I’ve tested and realise what the Subtool menu if you gonna create it like an another one for new menu, it is 100% bug. BUT without Subtool menu it’s work perfectly.
It will be great if ZBrush team will take a look on this issue.
On the screenshot, it shows another problem related with Subtool.
