This is killing me…
I have what I’d consider a pretty basic custom UI.
I’ve saved it to a file, AND used “Store config”, AND saved a StartupDocument (I’ve also saved my Icolors to a file):
However, no matter what I do, Zbrush rearranges my palettes:
If I:
Startup Zbrush (presumably with StartupDocument.ZBR)… palettes are swapped.
Load saved UI from prefs menu… palettes are swapped.
Restore custom UI from prefs menu… same thing.
Open my separately saved “Default” .ZPR file… palettes are swapped.
Cycle to my saved UI via the “Load next User Interface Layout” button… same thing.
I just did a clean install of 4R5, and reconfigured everything from scratch, and ZBrush STILL rearranges my palettes.
Mac OSX 10.6.8, 12 core Power Mac, 8GB RAM
To add to the frustration, I can NOT simply drag the palettes to my preferred order. If I try to move them, they simply disappear from the trays when I let go of the move widget.
Any ideas?
