Custom Interface - icon below screen bottom cannot be removed
I have my own modified interface that I have been using for a long time, but now I want to change a few things. Problem is that I can remove all icons and sliders that I want except one that is the lowest of a vertical column (left side) , When activating Enable Customise, the entire circus sinks a little and that icon hides below the bottom of my screen surface - I have a 24inch set at 1920 x 1200 - and whatever I do, I cannot get hold of it to drag it off.
A problem that is more annoying than vital, but I still would know how to solve this.
Is there a way to get rid of it without having to configure everything right from the very beginning?
Thanks!
I have found the solution myself: clicking the ‘Menu’ icon at the top hides the menus, so the entire block of data moves upwards, and this is just enough to grab the icon at the bottom and drag it unto the workspace.
Perhaps someone somehow can be helped with this someday.
Good tip!
A way to do it is to set temporary the screen in vertical format instead the normal horizontal in the resolution settings of your operative system. This will give you a very long vertical aspect ratio. It will be awkward to have the screen rotated vertical in a horizontal monitor but it is only a few seconds enough to do the changes. Unless you have a monitor that can rotate, as I have.
