in my hotkeys i have the “S” button to solo mode.
hi, you just have to assign a key input for the Draw Size if you had swapped it for solo mode.
for example if you assign the K input key to draw size, the sticky key will apply (if enable in preferences) when you hold the K input on your keyboard.
Hope this helps,
Nicolas
         That was an easy one ^^. So in the same way i can add focal shift or z intensity to a hotkey. im trying to mapped in a keypad. Thank you so much!!
