curveStandard brush broken in r7?
Is curveStandard brush broken in r7 or am I being an idiot? (It could easily be both)
As I recall, it should work by drawing the curve, and then when you touch the curve, or move/drag the curve, the tool should be sculpted along the entire length of the curve.
I can’t seem to get this to work any more. Now when I try to drag the curve. The tool is just sculpted under the cursor, as if I were using the standard brush.
Similarly if I use curveEditable. When I drag the curve around the tool I expect to see the tool deform under the entire length of the curve, but it just seems to happen under the cursor.
Am I forgetting something really obvious?
Thanks in advance
We have another thread started on this subject. your not wrong. Many of us have made mention of this since R7. We are waiting for a response from Pix still. I am sure they are working on a hot fix. :wink:
Getting the same problem with the CurveEditable brush when using it with polypaint.
Anyone got the link to the original thread please ?
Thanks, where is the other thread of which you speak?
http://www.zbrushcentral.com/showthread.php?191685-curveStandard-brush-broken-in-r7
Here ya go. I do hope that these threads get Dev notice.
