I’m using 4R7 and having a problem resizing an already drawn curve strap snap tool. I know all you have to do is resize the brush and click on the pre-existing line and it will update the overall size of the strap but it’s not doing that for what ever reason. Has anyone run into this and is there a fix?
Well I’ve found that if I size the brush with the S key it doesn’t update the size but if I adjust the “Draw Size” from the slider at the top of the UI it works… Some kind of bug.
