Hello, I am trying to follow a tutorial that wants me to change the Max Points setting for a curve and I am not finding this setting. It is supposed to set how many edit points are on the curve and in this case is used to make dots at even spaces along the curve. Has this been removed? If so, how do I go about doing something like this in the current Zbrush? Thanks guys.
Did you look in the Stroke Palette under Modifiers?
Yeah, did I somehow miss it? Just turned comp off or I’d check again lol.
Just checked before work. I don’t see a max points setting in any of the curve menus or in the main modifiers menu in the stroke palette.
If not there look under Brush modifiers.
Thanks to Zber2, I can now get the points count lowered on the curve by pumping my brush size through the roof. Does anyone know a reliable way to know how many points your curve will have based on the brush size by any chance? Other than a lot of trial and error I have no idea right now. Sounds like the max points setting may have been removed. Seems odd as it does seem like it could be a useful setting unless it’s been replaced by something more reliable than guessing with your brush size heh.
Thanks Zber2. It won’t let me reply back to your pm. Says you either have them off yourself or aren’t allowed to receive them
