Cursor dissapears when hovering on buttons, and also the center of the red circles.
Hi, I’m new here. This is happening from about two weeks ago, don´t know if it was a graphic driver, or a hang that I had during an Iray render with a bit too much vram OC (forgot to change profiles :p)
Thing is, that I have a 4k display, I¡m having it for 3 months now. At the beginning was fantastic, a lot more room for brushes, more open shelves and still a lot more room to work, plus, the cursor worked just fine, I had to set the W10 display scale at 150%, and ZB followed it perfectly since the floppy disk icon when it starts loading.
Now, since that very moment, I can barely see the floppy disk, and inside ZB, is just impossible to browse the lightbox, the menus more or less, as the icon goes back to normal when is not on the working window, or hovering any icon, for instance when scrolling up/down, those arrows are displayed at 4k with 150% like the rest of the program, place it over an icon, or a slider, button etc, anything and turns so tiny that is impossible to see it.
The only way I’ve found to temporary fix it, is set the display drivers at 1080P, reset, it works at 1080p scaled, so it looks horrible and I have a 4k for nothing, but I can set the native rez again, and the 150% dpi, reset and it works, but, it works for just a few on/offs, or not even that.
Is there any way to fix this once an for all?? I’m sure that it was since three drivers back, I keep updating them hoping to get it solved but nothing (I have the latest ones by the way) Thanks in advance.
