Cursor Artifacts while screenrecording
Whenever I’m trying to record some footage using screen capture software the recordings always look scrambled around the mouse area.
I tried OBS, Nvidea ShadowPlay, and even fraps.
The cursor itself looks fine while working, but the recordings always come out scrambled like this.
Anyone know a work-around ?
I have the same problem.
Anyone found an answer?
@BenRidgway
Not the solution, but a solid workaround.
nvidea’s shadowplay is free and doesn’t give this cursor artifact.
So I use that from now on.
Unfortunately, that didn’t fix it-
Screenshot 2024-03-06 101141
fix it on the “sources” tab, choose the “display capture” and select the cog setting button, then untick in " Capture Cursor". Hope this help ^^
