Cube tool size question
Hi all, quick question, how do I get a cube with a single poly face?
When I drag out my my cube it always has 544 points, is this the default setting?
I want to practice with the Zmodeler tool with the minimum faces.
Cheers :slight_smile:
EDIT: 4 faces per side would be great as that’s how many are on the tutorial video.
Morning Robbie,
You can just add x Res 1, y Res 1, Z Res 1 under Initialize once you have made your 3D mesh tool a polymesh 3d.
Many thanks Wyattfox :slight_smile:
I did find a method using a Polyshere but yours is much faster method that I have been using. :+1:
