cube dissappears when trying to initiliaze.
I’m trying to initiliaze my cube to start editing it with zmodeler, but when i do the cube disappears. It’s still in the subtool pallet but not visible or editable. I tried turning it into a polymesh 3d and that seems to work, but then my zspheres i use as a base disappear completely (it’s gone from the subtool pallet)
So my question is: how can i initialize my cube while i have zspheres as a subtool?
The cube is there, it’s just too small and you can’t see it because is “inside” of zsphere… Hide the zsphere and you’ll see it…
You can scale the cube up or unify it to make it bigger… :wink:
thanks for the answer! unify worked. scaling, for some reason, did not. However i got the result that i needed. i did notice my transpose menu is now floating way of in the distance, do you by any chance know how i can recenter it on the object?
Transpose menu???
Are you using the gizmo or the transpose line?
With the gizmo you can alt click the “home” icon…
With the transpose you click on the white circle…
yea i meant the gizmo haha…
thanks a lot, that worked :slight_smile:
