ctrl z not working
Hoping someone can help me out. For some reason my CTRL-Z for undo no longer works in Zbrush. I used to be able to undo till my hearts content but now it’s not working. I have to actually go to the tool bar…go to edit and click undo. When I hit ctrl now the only options that come up are for masking. This is driving nuts!! Not sure what possibly could of happened. I there a way to reset all hotkeys? Has anyone else had this issue?
restart Zbrush and it should fix it. If it doesn’t you can map your hotkeys again for undo and redo. I believe Marcus wrote a script to hard code them…but I could be wrong on that.
Not a script, you can simply edit the StartupHotkeys.txt file. See the bottom of this page:
http://docs.pixologic.com/user-guide/keyboard-shortcuts/defaulthotkeys-file/
Make sure you edit the file from the Public folder at the path given on the page.
