Critical Bug localized in Zbrush2018 - meshes moving when brush size is 1
Hello Zbrush-Team,
I was wondering since I’m using zBrush2018, why my meshes often loose their position.
I have found today out that the this is a bug that appears, when the brush size is “1” and you press ALT:
Than the mesh will be moved without any control or warning.
Try the following to repeat that:
  • Take the standard brush
  • Set Draw size to 1
  • Press alt (like you would do to invert the Z-direction)
and just “sculpt”.
You will not sculpt, instead your subtool is wandering through the space…
Please check and fix soon!
Thanks!
…than yours tools wandered even before cause it’s not new to 2018
At least I haven’t seen the bug before, and I have only zbrush2018 at the moment.
I am working close on details of meshes, for fixing small issues after zRemeshing at the LowPoly.
