Hi
When exporting a ZBrush image to be used in other programs, you may need to have an alpha (mask) created. This mini-tutorial describes four common methods that can be used when creating such alphas.
The following is a sample image that was created in ZBrush. The image is composed of 3 rings and a sphere. Each of these items was drawn with a different color and material.
The grayscale images are various alphas that can be created from the above sample image.
Instruction for creating the alphas…
Alpha 1: Creating a grayscale mask from depth(z) values…
This is the most common method as it allows depth information to be converted to alpha. This gray scale alpha represents the relative depth of each Pixol in the canvas. White=nearest, Black=farthest. This alpha can be used when applying ‘special’ depth-sensitive effects (such as fog and depth-blurring).
Instructions:
A. Select the MRGBZTool, Unpress TOOL MODIFIERS
AUTO CROP.
B. Click in canvas and ‘drag’ to ‘grab’ the canvas. A new Alpha will be added to the ALPHA Palette and a texture will be added to the TEXTURE palette.
C. Export the new alpha from the ALPHA palette.
D. Switch to the target application and import the Alpha.
Alpha 2: Creating a simple B&W mask from Depth values…
Same as above with the added step to convert the grayscale into a B&W mask.
Instructions:
AUTO CROP.
E. In the target application… Select all ‘black’ pixels of the alpha, inverse selection and fill selection with white.
Note: When an image has a simple flat-color background (such as the above image), you may choose to create the B&W mask from the texture in the target application by selecting all ‘background’ pixels and inversing the selection.
Alpha 3: Creating a multi-levels mask from color intensities…
This method is most effective when objects have been drawn with different colors (such as the above rings). This alpha allows you to select different parts/objects of the image based on color intensities.
Instructions:
SHADED MODE , Unpress TOOL
MODIFIERS
AUTO CROP.
B. Click in canvas and ‘drag’ to ‘grab’ the canvas. A new Alpha will be added to the ALPHA Palette and a texture will be added to the TEXTURE palette. You may now export the flat-shaded image and use it to create color-based selection in the target application or continue with the next step and export a grayscale version of the image.
C. Convert the new texture to an alpha by pressing the TEXTURE MAKE ALPHA button. Export this alpha from the ALPHA palette.
Alpha 4: Creating a multi-levels mask from material indexes…
This method is most effective when the objects have been drawn with different materials. This material-index channel allows you to create masks based on the material index of each object.
Instructions:
AUTO CROP, Press DRAW
MRGB mode.
C. Export the new texture from the TEXTURE palette in PSD format. When exporting this texture in PSD format, you’ll be presented with the following dialog box…
This image contains material-index imbedded within each pixel.
Would you like to save the material-index as a separate channel?
Press “Yes” and the PSD image will be saved with an added material-index channel.
D. Switch to the target application and import the texture.
E. In the target application…Select the extra channel that was imported with the texture. Each pixel in this mask channel has intensity value equivalent to the index number of the material that was used. In most cases, the material index value is small and therefore this mask channel may appear to be completely black. In order to clearly see each of the sections, you will need to increase the contrast of this channel (manually or by using auto-contrast).
I hope that you’ll find this useful (and not confusing)
-Pixolator
