Create New Texture from Cavity Mask Out of Memory Error message deprecated!
Z4R6 and Z4R7 32/64-bit has old deprecated code in your memory check routines for Create New Texture from Cavity Mask, when the “4GB memory limit check” exceeds some hardcoded value in your code:
Two error-message windows appear, - clicking OK x2 - then Zbrush continues to work.
Reproduce: Win7, 8GB RAM
  1. Take one 21.7 million poly subtool, (UVd properly)
  2. 1 UV map size 4096
  3. Do a Mask by Cavity
  4. Create New Texture from Cavity Mask
Error window pops up “Out of Memory, backup is saved, ZB will now exit, etc…” and it does nothing, I can press OK: ZB completes the Create New Texture from Cavity Mask function and I can continue working.
