Hi there,
currently working on a mesh with small detail lines needed.
I needed a soft structured thin line.
Mask by polygroups on 100.
I use a spray brush and an spray alpha, with a bit smoothing,
with lazy mouse and a size of 1.
This leads to very often crashes.
Or the object is instead moving (no idea why).
With a brush size of 2 it works, but the lines are too thick.
The object has already 7mio. points, so I don’t want to increase its size to use a bigger brush size.
Any ideas?
EDIT: found that without Mask by polygroup it works better.
