When copy with ctrl,mesh start flying&lost direction
Hi @AlexDubnoff,
Can you explain what do you mean by “mesh start flying and lost direction”, is it possible to capture a video sequence for the issue ?
Nicolas
Hi/when i copy mesh with hold ctrl in 21.6.6 - my mesh starts flying ( sliding )across the screen instead of being copied directly opposite the previous one.(im use transpose tool/with gismo all good)
When i try upload mpg or mov zbrush video i have this window
Hi @AlexDubnoff
You are using the Action line and it might not be lined up correctly. You will probably see it better from top view. A better way would be to use the Gizmo3D.
thank you…but im not talk about gismo(as i sayed with gismo all good),i asked about transpose tool.In previous version all was good and copy operation with transpose tool keeped dirrection…
Yes, there does seem to be a problem with using the action line in version 2021.6.6. If you wish, you can report it to Pixologic Support. They might not be aware of it. But for now you can use the Gizmo3D.
Hello!
We are aware of an issue in the current version of ZBrush with over-sensitive movement when using the transpose action lines to Ctrl-duplicate a mesh. There should be no issue when using the normal Gizmo manipulator, so I recommend using that for the time being.
Thank you!
