Hi
Sometimes when trying to convert a .tiff files to a .map file using the .bat file given by Scott Spencer, sometimes it does not convert at all
I was wondering why this happens, I cant find a logical reason why.
Anyone?
cheers.
Hi
Anyone?
cheers.
Hi kyuss202 ,
Are you making Displacement maps ?
I had a problem getting it to convert my tiffs until I saw I had the wrong Quick Code in the options for Multi Displacement 2 plugin .
Is this the plugin you are using ?
Make sure you have the quick code set to :
DE-LBEK-EAEAEA-D32
I had the wrong code in there and after I changed it the Converting worked just fine .
I hope that helps .
Best Wishes ,
Essclock
yes, sometimes it just wont convert but I kept creating new ones and then it worked.
So I dont really know why this happens.
