hello! everyone! I am an amazing Zbrush beginner! Recently I encountered a problem…
After laying a sphere3d or cylinder3d in canvas,I want to use projection master to add some displacement. But a window always pops up…it shows"Tool must to be converted to polymesh3d tool in order to use deformation projection" .
What should I do to continue my desire?
p.s If I import .obj or .dxf files,the message won’t show up.How come?
Thank you so much!
When you are in EDIT mode, the ‘Make Polymesh’ button will be active in the Tools pallette…Even a Sphere tool can be converted to a Polymesh to enable PM…
The reason the imported object doesn’t produce the alert, is that it is automatically converted to a Polymesh upon import…
(And Welcome Aboard! )
The process would be to convert the Sphere into a Polymesh, clear the screen, look in the Tool pallette, and you will find your new tool. This would be the same for any tool you make.
