Hello @RoyalSkies
I don’t know anything about the lashes in this asset. Is it an actual piece of geometry, or are they a texture applied to another piece of geometry?
If it is a texture then you would need to edit or adjust the color of the texture. If it is geometry, then you would control the color the way you would with any other mesh in ZBrush, namely:
Adjust the active color. If the mesh has no polypaint or applied texture, it will display the active color and material.
Apply Polypaint.
Apply a color texture.
If you are unfamiliar with these concepts in ZBrush, then the correct place to start is probably here.
