Control Mask toggle is not working
Hello, When I use Ctl to toggle the mask options I am unable to select Mask as an option. I have clicked Mask Lasso and then press Ctl and instead of mask lasso like usual it is square select or lasso select HIDE. I have been unable to mask off my selections to alter my model and instead continuously cuts the selection out.
Please help me figure out the issue, this has never been a problem and I have watched so many tutorials and read forums but no one else seems to have this happen.
Hi @kelseyzbrush
It sounds like the Shift key on your keyboard might be sticking. Do you have another keyboard you can try?
Which version of ZBrush are you using?
I think Zber2 is correct here. The selection marquee brushes will come up if you hit Shift+ Ctrl, so look for any issues that might be causing the Shift key to activate, either at the hardware/driver level, or possibly with some OS feature like sticky keys.
