Greetings,
Does anyone know if ZBrush can be launch from a command line?
…or automated launch from within Maya via a system call?
Any help greatly appreciated,
Greetings,
Flinestone - Not that I am aware of. It is possible to do the reverse though. To open other programs from Zbrush. Zbrush’s SDK is not finished.
As I mentioned though, you can use Zscripting to open other programs.
r
Flint,
I just tried a two line batch file (.bat) that launched ZBrush2 just fine. Have you tried that?
Sven
Yes,
I have used this from a windows app. Therefore if you can connect to any C/C++ plugin you can type this into the .c/.cpp file.
static char *ZB_Exe = "C:\\Documents and Settings\\Chris\\Start Menu\\Programs\\Pixologic\\ZBrush2.lnk";
ShellExecute(0, "open", ZB_Exe ,"","", SW_SHOWNORMAL);
You could just put the path to the ZBrush.exe , but I don’t remember why I chose this method. Maybe so I would only open a single instance???
