Hello! I just started ZBrush and I love it - I purchased two separate rope curve brushes from Art Station, and since they are very similar, was wondering if there was anyway to combine them into a single Curve Brush?
Thank you so much for your time!
Hello @RoyalSkies ,
Yes!
Load the brush you would like to take content from. In Brush> Create select “Copy Meshes” or “Copy One Mesh” depending on the situation.
Load the brush you would like to combine the content into. In the same menu press “paste append”. This will paste the meshes from the other brush into the current brush.
Save out your new brush with Brush> Save As for easy recall later.
A note on this. While the brushes may appear similar, it is possible that each brush has different settings tailored to get the desired effect with the mesh. It may be the case that the imported meshes don’t perform the same way with the new brush’s settings.
My god, thank you!!! That works perfectly!
My question has been answered
