Color Problems
So hi guys i was painting my model using polypaint and everything was fine, saved the ztool so i could work on the other layers of the skin later. When i re-opened my ztool i noticed there were several weird dots with the colour of my current material, for example: if skin was blue the dots were on the same colour of the current material, like the red wax or mat cap grey. These arent dots that i forgot to paint… even if i fill the object with some other color it wont fill these little dots. I dont have any masks on… Whats happening, sorry if this is a silly question im new. Thanks for the help
Sounds like you painted different matcap materials onto the polypaint at some point. It’s an easy fix: select any brush, turn off RGB/MRGB and turn on just M, select the FlatColor Matcap, and then use Color: Fill Object.
This will erase all material information while preserving the Polypaint’s RBG colors. Then you can switch back to a matcap of your choice (remember to switch back to RGB before painting)
thanks a lot man =]
