I’m trying to dynamesh this object. But when I do, the color gradient on the surface becomes somewhat random spotted mess in some areas. Is there something I can do to fix this?
@cg_S Don’t know what’s causing the issue but a possible workaround is to set a history point just before you Dynamesh. Then Dynamesh. Next run Project History opting for Color only (disabling the default Geometry Projection option). Project is found in the Subtool section of the Tool palette. Good Luck.
