Closing and Opening Files
Hi…I am new at ZBrush…but I am use to Micrsoft’s “Windows” format…you know.when you open file you get to choose from “New-Open-Close-save-save as”
I don’t see those options in ZBrush…after I have imported an object into ZBrush…work on it…and want to…save as and close…so I can open another file…there is no …“CLOSE” choice window to choose.The only way I have been able to close a file and open a new file is to close down the ZBrush software …then I get the “Save Change-no-cancel” window …then reopen the ZBrush software to work on a new project…This can’t be the way it was desgned…Help…what am I doing wrong…Close and Open Problem.txt
Hi, just download all tutorials at www.pixologic.com, read them carefully and try again :slight_smile: BTW for cleaning up the layer press CTRL+N
Hi Bouguereau,
in this version of ZBrush (both demo and commercial) there is no new document button. But I think V.1.23 due out very soon will have it. The Documents Palette contains the Open and Save documents. You can also export a 2D pic. (It is not neccasery to clost the document before you open a new one. When you need to open and save ZTLs use the Inventory sub-palette in the Tools Palette.
I hope some of this makes some sense–Call out for more if needed.
This thread may help.
Upham
Credits to ZuZu
Hi Bouguereau, and Welcome to ZBrush Central!
As Mulvo said, version 1.23 does have a ‘new document’ button.
Hopefully the information in Upham’s link will be useful to you until you have version 1.23.
-ZuZu :slight_smile:
When will version 1.23 become available.
