Close Holes? 4R7
Hello,
I just started to learn the new features of the ZModeler brush. Just simply awesome btw! I am so happy I can extrude and bevel without edge looping and panel looping etc;
I wanted to close the holes of a mesh I have. I see the close hole function of the ZModeler Brush but when I click on an edge it doesn’t appear to do anything? Anyone know what action I am supposed to do with this close hole function in ZModeler Brush?
Thanks in advance
Ghost
With Zmodeler active, it’s Edge > Close. Click on an edge of the hole to close. You can also use the traditional close hole command in tool > geometry> modify topology> close holes.
If you’re not getting any results when you use the close hole command, it may be because you’re asking it to close too complicated of a gap. Some degree of edge bridging (edge > bridge) may be necessary first, to reduce the gaps to something Zmodeler understands.
Thanks for the fast reply! I will look into those options, Thanks!
