Is there a way to clear the quick pick texture menu of all the textures? Since losing the functionality of alt tabbing back into zb and seeing the changes I made to my psd in photoshop i have to reimport the texture. I can clear out the Texture>images section with the R button. These images do not clear out of the quickpick menu when loading from Tool>TextureMap on the right.
If you load a texture onto a model using the ‘Import’ button on the popup that appears when you click the Tool>Texture Map thumbnail then it does not appear in the main Texture palette.
I’ve written a little macro that allows you to load a texture and then refresh it (using a hotkey for the macro button). See here:
