Do you remember the worst time at work? The machine card is deadly, it will crash at once, and the rendering will take a whole day, but there are still problems to be re-rendered.————
Clarisse ends all this
If you don’t know Clarisse, you may despise him. What’s the use of this software in Chinese for Clarisse? Isn’t it a real-time renderer, hairy?
But if you actually install him and import your scene into it, copy a few casually, your eyes will light up immediately!!!
What is Clarisse doing?
Clarisse has been silently involved in almost all recent American blockbusters. Experts don’t tell you how he did it.
You will find out how well they work, but you don’t know how to do it. Do you think they’re just computers? No, it isn’t. It’s the same computer. They just use Clarisse.
Clarisse is different from other renderer software
A series of renderers, such as Arnold Vray, can render real effects, but they are only renderers. UE4 and other game engines can be rendered in real time, but they are just game engines.
3DMAX and maya, houdini, etc. can be modeled and rendered, but they are only modelling.
In clarisse’s understanding, they are all middleware. And Clarisse really integrates model / material / special effects / animation / lighting rendering. And you can operate unlimited number of polygons, unlimited fireworks and lightning. Unlimited water foam.
Claisse Course in Zhufeng Community
Zhufeng Community will start from scratch and learn all the techniques of clarisse, so that you can quickly switch from 3DMAX or Maya Houdini to clarisse. Learning Clarisse does not require you to discard existing three-dimensional software, but it can activate your creative inspiration. Let you really work for your work, not be restricted by polygons.
You can learn community lessons by introducing Clarisse in one day and producing works in three days. So don’t hesitate any more. This is English software, there is no Chinese version at present, honestly follow the teacher to get started! The teacher will take you flying.
We’ll learn clarisse’s array methods, brush a brush, thousands of grass will come out, a little bit, a forest will appear immediately. Like the following scenario, model grass and trees in less than 10 minutes. Maybe you don’t believe it, but it’s true.
In addition, this course will learn how SpeedTree creates custom trees, Houdini creates mountain terrain, and so on. All of these are the most advanced and fastest manufacturing methods at present.
Do you need to learn nuke to learn clarisse?
Nuke is 2d, although it can be 3d, it is still 2D. Did you ever think about the feeling of lighting up to 1000 lights in real time in the scene, wherever you click? Nuke can’t do it.
With clarisse, it seems that the layered rendering that nuke needs to do is not necessary. Clarisse can output Z channel, object ID and other 3D software. nuke can be used to produce depth of field and smoke. however, Clarisse can import VDB smoke. now, where you want to put it, the real clouds, the real smoke, the real atmosphere, and the lights hit the atmosphere, the fog will be effective.
In front of clarisse, nuke is only 2 days old. 3D function can be lost.
What scenario does not require clarisse?
For example, if you just make a single character, a low polygon model, and very few polygons, you don’t need Clarisse at all. Both 3DMAX and Maya can be done.
Clarisse is designed for big scenes. If you were just a person before, Clarisse could be 10,000 people. If you just use Clarisse to do some small scenes, you might really be wronged with the software.
Last! Put it out right away, don’t rush to it.
