Well holy crap. I’m apparently one of the first people in the US to get a 27QHD. Wacom’s US support staff doesn’t even have one. There ARE issues with it. Somehow I fixed it though. This is a heads up for anyone that has one on the way or is dealing with these silly issues.
First. As always, Wacom’s very first driver for the 27QHD is crap. My issues have to do with using Windows 7 64bit. I don’t know if these problems are on Windows 8 or anything else.
Issue #1: Wacom’s display properties doesn’t work at all. So you can’t adjust the brightness, contrast, or anything. You just get an error message saying the a Wacom display isn’t installed even though you’re looking at the error message on your frickin’ Wacom display. The fix is a Windows update that installs “FTDI- Other Hardware - USB Serial Converter” After installing this the display properties works fine. It took Windows an extra day to find this on it’s own. Wacom had no clue so I called and told them about it. Hopefully it’s fixed for everyone in the next driver update. There is also “FTDI - Other Hardware - USB Serial Port” that I installed the next day, but it didn’t change anything.
Issue #2: The battery percentage for the Express Key Remote is completely inaccurate. There’s no fix yet for this, it’s a bug. Luckily there are blinking lights at the bottom of the remote that tells you if it’s charging or about to run out of juice.
Issue #3: The touch ring stopped working on the Express Key Remote. I thought it had to do with the RTDI update breaking something after it fixed something else, but it’s not. If you remove the back panel of the remote, there is a reset button. I pressed that and the touch ring works again. Again, Wacom support has no clue about this and they actually wanted me to ship it back to them for a replacement instead. If it keeps happening after future updates and they actually get a clue on how to support the 27QHD I will send it in for a replacement.
Other than those issues that wasted 3 whole days it’s pretty nice. Much better display than the 22HD, no weird glittery anti-glare stuff on the screen.
