If you work in the field of products or games assets area, you know that Chesterfield patterns are time-consuming, complex, and require a high budget for vertices. If we have these Chesterfield structures in procedural leather material in Substance Designer, it will give us a more flexible workflow!
So let’s see how to make Chesterfield in the Substance Designer!
More Info:
https://www.artstation.com/a/16359215
Contents:
- 125 minutes of unnarrated videos
- 1080 Resolution
Chapters:
Chapter 01- First Step: In this chapter, we create Chesterfield’s basic structure and add surface details and additive details to them like wrinkles and buttons, and after that, we are going to make our underlayer surface that these. We will use different maps and blend them to achieve the desired result.
Chapter 02: The next step is creating the color and roughness data for this material. For this tutorial, we use the gradient map to make our color data with a few colors and blend them with different grunge maps to get what we want. And for roughness data, we are using a simple and effective way for this type of material.
Software Used:
Substance Designer
Level:
Intermediate
Prerequisite Basic knowledge of Substance Designer
Attention: clean SBS file is included in this product that you can study over that (version of the designer should be 11.3 or above)
Attention: all videos are unnarrated (it means there are no voice-over videos or subtitles)
Do you want it ?
Scifi Padded Wall Tutorial - VOL 09 :
https://www.artstation.com/a/16161943
Metal Railway Tutorial - VOL 08 :
https://www.artstation.com/a/16017894
Broken Roof Tiles Tutorial - VOL 07:
https://www.artstation.com/a/15815559
Metal Retaining Wall Tutorial - VOL 06 :
https://www.artstation.com/a/15570800
STYLIZED PAVEMENT WITH MOSS Tutorial - VOL 05 :
https://www.artstation.com/a/15406536
Stylized Plaster Wall Tutorial - VOL 04:
https://www.artstation.com/a/15331498
Handmade Mosaic Tutorial - VOL 03:
https://www.artstation.com/a/15064540
Damaged Concrete Tutorial VOL-02:
https://www.artstation.com/a/14950781
Broken Tiles Tutorial - VOL 01:
https://www.artstation.com/a/14922290
Facade In Substance Designer Tutorial:
https://www.artstation.com/a/5308958
