Changing the default UI Colors and standard Mat
I have got two simple questions regarding the customization of ZBrush:
  1. How can I change the default material from red wax to a custom matcap? I already created a suitable matcap via C4D and stored the material inside ZBrush’s material manager but I can’t set it as the default material which loads on startup :frowning:
  2. Same for the custom UI colors; I created a custom color scheme and saved it under Zstartup/UserInterfaceColors but I don’t know how to set it as the default startup color scheme :frowning:
Thanks for any help,
Daniel
#2. Once they are as you wish, save your config with shift+ctrl+i keys.
Download and install ‘HandlebarStartupMaterial’ plugin by TVeyes in post #7 here. Install and usage instructions are in the post.
Note: It says ZBrush 3, but works just fine in ZBrush 4R5.
Thanks guys, that works fine :slight_smile:
Best regards,
Daniel
