Hi, I wasn’t sure if this should be posted here or in the thread below, but its a startup problem so I figured here? :o
Anyway, following this:
http://www.pixologic.com/docs/index.php/Changing_the_Default_Material
I want to change the default material loaded by zbrush from the red wax one to “MatCap White Cavity”. I have tried both just selecting this, painting it onto the canvas, then saving in the ZStartup folder, which didn’t work. Then I realised the tutorial says you have to load over the red wax material, so I found the MatCap White Cavity MatCap in the ZData folder, and loaded from there over the red wax, painted on canvas, saved at StartupDocument.zbr in ZStartup folder, and still, didn’t work
Am I missing something? The only thing I can think of is that I don’t have ZBrush installed on my C: drive, but I highly doubt that would make any difference?
Thanks,
- Ricky
) red wax matcap.
but no problem now
Scrtips
