Changing brush size by holding down a key and moving the stylus?
Is it possible to do this? I know you can either hit S and click drag on the bar or use the spacebar menu, is there any way to just hold down a key and move my stylus left or right and change it? Similiar to how Krita works with the shift key or Blender with the F key in texture paint/sculpt mode?
I mean I guess it works with the S or spacebar, but it’s mildly annoying if you miss the bar or start sliding around the focal shift or Z intensity in the spacebar menu.
You can also use the [ and ] keys on your keyboard to step the size up or down in increments of 10.
“Zplugin > Adjust Plugin > Adj DrawS” just assign a hotkey to these menu items and it will perform the same way that you are referring to.
Thank you very much, that is exactly what i was looking for.
actually I forgot about this and I am using it instead
http://www.zbrushcentral.com/showthread.php?182163-ZAdjustor-v2-0-UPDATE-gt-v2-0-for-WIN-OSX
