Change to Move Topological in R8?
In R7 if you used the Move Topological brush with brush size 1, it would let you move smaller contiguous meshes inside the same SubTool really easily. In R8, when trying the same thing, it seems to lock the movement to what seems like 2 axis. Changing the camera angle doesn’t change which axis the sub mesh moves on. Anyone know of a setting to get this to behave like it used to?
Thanks for any help.
This still works the same as it did in r7 for me.
Do you happen to have your axis locked in your transform>modifiers panel?
No locked axis. It’s only moving on Y and Z as if X as locked though.
Fount the fix. I had symmetry on. Solution, turn it off, move desired mesh, mirror over. Sometimes it helps to zoom out. :roll_eyes:
