Change Default Export Settings
Does anybody know how to change the default export settings for obj’s? There are buttons I want disabled as default and it’s a pain going through and pressing them everytime. I have tried saving the StartupDocument and storing the UI config. Also tried making a macro which DefaultZscript points to and runs on startup:
[IUnPress,Tool:Export:Grp]
but this won’t work at startup because a tool is not active. Is there another place where this data is stored?
The Tool export options are for each tool or subtool. That is why you can’t set them globally. What you can do is make a macro that sets them for all subtools for the selected tool. This posts describes how:
http://www.zbrushcentral.com/showpost.php?p=798045&postcount=30
In your example, all you need to do is put
inside the DoIt routine.
HTH,
Thanks marcus for the quick response.
