I am trying to create a layer with cavity mask but it doesn’t work. I am not sure what I am doing wrong here or missing something perhaps.
So these are my steps:
- Create layer with record enabled
- Cavity mask, invert.
- Fill Obj with color (black with RGB set to 50%)
The cavity doesn’t get filled with the black color.
I also tried to mask cavity first, then create new layer and fill object and it also doesn’t work.
However, I tried without any layers, going through same steps as described above and works perfectly.
The idea is to have 1 layer with cavity map and other layers with polypaint.
Sorry, I haven’t used Zbrush for a while.
Any help is appreciated. Thank you.
