CanvasMaker Version 1.1 Zscript (Updated)
Inspired by Deevee’s An Exercise and A Round To it thread I developed this little utility.
The main attribute of the script is that it places your background plane automatically on the canvas clipping plane, sets a high mesh resolution and uses Flat Material. The other button is to automatically size the canvas area to your desired Texture Size, otherwise the script will just fill the current canvas dimensions and perhaps distort the texture you are wanting to use.
I hope this is of some use
Get it here
canvasmakerwidget.txt
UPDATE 1.1
Problem with Clipping plane value fixed, be sure to upgrade to this version
Great stuff digits. This script should be very helpful to all those members who would like to try painting using this methid. I will try it and post my results. It should speed things up a lot. Thanks a million :ex:
Digits; this is awesome :slight_smile: Thanks a million for all your contributions. I think I have just about everything you’ve made installed :wink: Great work!
:slight_smile: The ZScript King strikes again! I can think of many times that this would come in handy. Thank you!
your starting to become a script legend digits… thanks buddy for this awesome script…
way to go all mighty ZScript Master :smiley:
works good :+1:
Thanx Digits, 4 your Zscript Ingenuity .
I’ll put this baby 2 good use !
Stevie-rae.
:sunglasses: :+1: :+1: :+1:
Thanks folks, I appreciate the feedback.
Just a bump to let you know I have posted Version 1.1 which fixes a Clipping Plane value problem. Before it wasn’t calculating it correctly for all cases. So if you are using this be sure to get the new version.
Ztevie-Rae I have sent you a PM
I tried this method out D, and this is my first image using this method, I used one of my paintings as a brush, just to see how it would turn out. To me it looks like a pattern that was used on garments found in Tropical areas several years ago.
Thanks again for sharing.
a wonderfantastiful widget, Floyd and a veryvery beautiful painting, DeeVee! makes me smell silky seas! :+1: :+1: :+1:
  • juandel
Well done.
I like it.
cameyo
