Hi I recently purchased the latest version of zbrush but I can’t seem to view the Polygroups icon in the UI like before. I’m using a Wacom Cintiq Companion and below is a screenshot. I believe the icon is further down below but there is no way to scroll down. Is there maybe a way to reduce font and icon sizes in UI?
Hi Markus.
Bearing in mind that the recommended specs for Zbrush state a 1920 x 1080 screen resolution, you can scale the UI to fit some smaller resolutions by adjusting the button size in Preferences> Interface > UI > Button size. You will have to restart ZB to see the changes, and as always make sure to store the configuration via Preferences > Config> Store Config after making any changes in the preferences.
         If you hold Ctrl, you can click and drag to scroll that shelf (and others) to find buttons that are currently off-screen.
         Thanks! managed to change the size and now all is good
