Hey all. I have to say zbrush 2020.1.3 is the most unstable version to date. Had the most crashes than other versions. Though something to day really hit hard.
I did about 30 mins work on a sculpt and saved the scene ZPR file. Went back to it today and a completely random ztool I have never loaded up was in place of my sculpt! There was another ztool I was using that appeared in the scene as reference that was still there, though my actual working ztool Was gone and in its place a random file I worked on months ago.
I have had occasional issues like this with ZPR files in the past where the sculpt I worked on was just not in the scene. I usually save a ztool version due to the unstable nature of ZPR files though unfortunately didn’t this time. I’m so unsettled saving zbrush files that as an extra precaution I save out an obj from a mid subdivision.
Has anyone else encountered an issue like this with ZPR files? I’d really know why it would randomly do this. Most of the time they are usually fine though you never no when it will mess up like this. 30 mins of my life I’ll never get back
Nor is it a complaint I’ve heard in almost two decades on these forums, or at least since ZPRs were a thing. It seems more likely to me to be a misunderstanding of the way ZB works, but stranger things have happened.
As I said, it’s not something I’ve ever experienced since the advent of the Project file over a decade ago on multiple systems and program versions, nor have I seen it reported (usage issues are common, though). It would indicate a significant problem with your installation or hardware environment. If you can document this happening, you need to contact
