Can't transfer zBrush due to weird glitches
I’ve been trying to make my file be ported into Substance Painter. It kept crashing when making a new file using the project I’ve been working on, but I tried an (much) earlier save file and that worked fine. I’ve tried two different export file types, and I’ve tried merging the whole project together and experimented around with it, when I tried divide it wouldn’t do it, remesher outright does not work, saying it’s aborted midway.
So what the heck?
EDIT:
I tried remeshing one by one to see what the tools might be causing the issue. I’ve found a few that say:
Mesh does not contain polygons on the major symmetrical side. Remeshing aborted.
Edit Edit:
I tried finding all the tools in zBrush and deleting those with that response, but it still won’t transfer smoothly.
Is there anyway to salvage what I have and put it into Substance Painter anyway?
did some troubleshooting by deleting objects and seeing if substance painter could open the exported file, and found a simple cylinder was the cause of the issue.
