Can't see the noise/alpha on NoiseMaker-Plane!
ZBrush version: 4R8 P1
I only see a blank white plane in NoiseMaker (only when I press on the NoiseMaker-Window, I can see the noise/alpha until I release). - Of course, even if I then open the NoisePlug-Window, I can not see any changes after selecting the options.
The Problem does not exist when I open NoiseMaker in Tool>Surface>Noise.
Does someone know a solution for it? - Thank youNoiseMaker_2.JPGNoiseMaker_1.JPGNoiseMaker_0.JPG
You need to set the Strength slider to something other than 0.
Wow, so stupid!
Thanks for the prompt and competent answer.
