EDIT: O.K. I didn’t read carefully about your prob. Marcus has THE solution I guess. Sorry for spam.
Even though I didn’t know the trick marcus described, the axis plug in is THE one click solution you want, I am sure. Basics views should be implemented in zBrush imho.
http://www.zbrushcentral.com/showthread.php?161588-quot-Axis-quot-Plugin-for-ZBrush-4r2&p=1121916#post1121916
Modify your UI that basic views are immediatly available and you’ll almost never argue with zBrush navigation anymore.
That’s the only pic of my UI I’ve online. Left bottom corner are the swatches to change views.
https://m.youtube.com/watch?v=5_oC99iwhRk
If you are coming from another 3D package, I would recommend the Middle mouse button plug too (pc only)
http://http://www.zbrushcentral.com/showthread.php?183019-quot-Middle-Button-quot-Plug-in-for-ZBrush-4R6&p=1153134#post1153134
You can there chose between 3ds max, maya & blender navigation.
Imho very cool for zmodeller.
These two plugs hellped me not getting crazy about zBrush navigation.
BUT also took me away from clearly learning ZBrushs navigation philosophy… That’s up to you. Jumping from one app to another is much more comfortable now.
Good luck.
