Can't make my brush follow a curve as intended.
Hi guys, first post so tell me if I’m doing something wrong please.
I’m trying to build a belt for my character, so I created a brush, downloaded Curves Helper and made a curve with z-spheres so the brush follows it.
The problem, as seen in the (hopefully) attached picture, is that it makes some odd twists in the far left and right. Anybody knows why this might be and how to fix it? If not, is there an alternative to this method to create the belt without having to sculpt it entirely?
I’m puzzled as to why the belt is not placed centrally on the curve. That seems to be affecting what happens at the points where it has sheared. Try one of the straps that comes with ZBrush such as in the IMM Curve brush. (Just select the brush in the Brush palette and click on the curve.) That way you’ll be able to tell if it’s because of the curve or because of your brush.
