Can't install Z2
Hi,everybody!
My Z2 can’t load, So i unstall then i reinstall it.but I can’t install it for the wrong.
when i continu to the forth step,it give me the wrong message as the “wjview.exe”
i ghost my system image that i had before ,but still has the wrong,why?
my system is windows2000 pro+sp3.
who can help me?
That error is caused by not having java installed. Go to www.Java.com and check out the green box in the upper right of the screen. You’ll be able to install Java, which will then allow you to install Z2.
thanks aurick.
I done it what U said, i had installed Java.and now i can install Z2 without any wrongs,but i can’t load Z2, it give me the message “imcomplete file write”,then is “Zbrush2.exe is wrong,it will be closed by windows. U need to Reload it again.”
why?
You could have a bad installation or even a bad download.
Try uninstalling ZBrush and then reinstalling it to a new folder.
Also, please post your complete systems specifications here if you continue to have trouble (as per the message at the top of the Q&T forum).
thanks aurick
i had reinstalled the system£¬now it¡®s ok¡£
