I have a problem with inputing text in text boxes. “Rename subtool”, 3d Text Plug-In, creating custom UI (name). The program does not display text in these inputboxes and does not allow anything to input. Numeric values (dynamesh, zremesher etc.) work fine. Faced someone such problem?
Which operating system are you running?
Windows 7 x64
Do you have a high resolution display? If so, make sure that high DPI scaling is not taking place. That can prevent the fields from working properly. Right-click on ZBrush and choose Properties. Go to the Compatibility tab and then make sure that the check box is active to override high DPI scaling behavior.
Thank you. But it does not help
